Trickflow heads port location?
Old 02-15-2014, 12:08 PM
BigDB's Avatar
Default Trickflow heads port location?
I have LS2 225 TFS heads and a ported FAST 90. While I had the engine out I noticed that the intake and head ports don't quite line up (see pic). Is the port location moved on these heads? I know the valve angle was changed but not sure of port entry. If so is there a manifold that is for these heads? Maybe a Victor Jr? I wouldn't be to worried about it as the engine runs very strong but I have a dual stage plate on the car with intentions of spraying a 300 but Im worried the fuel/N2O charge may pool a bit on this lip cause issues or a part throttle backfire. Thoughts?
Old 02-15-2014, 07:08 PM
garygnu's Avatar
chrss1313 made up some thick rubber spacer to help the ports align better .you can use some thick mr gaskets gaskets also .
Old 02-17-2014, 09:44 AM
BigDB's Avatar
I'll look into this. Thanks
Quick Reply: Trickflow heads port location?
