Burning Oil/Oil Resrictor Question
So I am chasing some oil burning issues with my new turbo build. Here are the specs..
Specs: 78mm Turbonectics
Oil Feed -4
Oil Drain 5/8"
Oil Pressure:40lbs idle, 60lbs cruising, 75 Cold
So when I initially installed the turbo it smoked a little and after tweaking the drain hose it stopped. So I installed a catch can and after letting the car sit for two weeks it smokes like a freight train!! Obviously oil is getting in the downpipe. Now the drain is not ideal being that its is at about 45* but unfortunately its as best as its going to get due to a super tight engine compartment. I know the turbo is getting plenty of oil being that it is getting past the seal. I talked to a local turbo expert and he told me to make sure the drain was optimal in both size and drain angle. Second he stated that with that high oil pressure and -4 line he thought that the volume of oil was too large. He recommended reducing the line size to -3. Do that I have already plumbed -4 I would like to keep it.
My questions are:
1. Is oil getting past the seals immediately detrimental to the turbo?
2. What size oil restrictor should I be looking at? I wouldnt mind getting a couple. I want to use the "least restrictive" restrictor that stops the oil from passing the seal.
3. Did the newly installed catch can contribute to this problem? If so how?
Any help would be VERY APPRECIATED!!
Oil Feed -4
Oil Drain 5/8"
My questions are:
Journal or ball bearing turbo ?
What size oil feed did the manufacturer/supplier request ? If journal, I would highly doubt anyone would recommend a -3
Is it a proper gravity drain ? ie is the discharge level higher than the level of oil in the pan ?
Without knowing how you've configured this catch can, no way of telling.
Yes, center section is higher the drain into pan.
LS6 valley cover to catch can. Catch can with one way valve to throttle body. Valve cover to turbo inlet.
You probably should remove the catch can fitting that goes to the intake manifold and see if it quits smoking. Cap the fitting on the intake.
With 2 possible issues, you need to eliminate one.
I asked the same question about oil feed for my BW journal bearing turbo and got every answer under the sun...
Ron
Ron
I blew my engine with this issue! My return was - 10 with brass fittings and my feed was - 4 unrestricted. It smoked a bit and I thought nothing of it. I raced my buddy on the freeway and the entire thing went up in smoke. I pulled the engine apart and found 3 bent rods from oil hydrolock. So i re assembled the engine with forged internals, did a - 12 return and an fittings and still use the - 4 feed. haven't seen a puff of smoke since.
Ps.... Borg Warner did not want a restrictor used on the journal bearing turbo, so I never used one. I could also tell it was oil from the turbo because my bov was spitting it out.
