Opinions on 4l80e Converters
We offer a 278mm HP series converter that falls in your price and horsepower range. They are available in your choice of 2 stall speeds. 26-2800 and 3-3200. It is a very stout converter that performs well and has excellent street manners. In order to run the converter you will need a dished ls flexplate. We offer one for 150 dollars... Definitely need to get rid of the 310mm...
-Brian
-Brian
The 4l80 flexplate is flat and is a 6 pad design rather than the typical 3 pad ls. You can try and find a factory dished style ls flexplate or opt for the sfi certified one we stock. Most converters for your setup will be the LS 3 pad design. We offer a billet 4l80 6 lug converter in any stall speed you want, but will be outside of the 500 dollar range.
-Brian
-Brian
The 278mm 3k stall will be a tighter driving converter than say a 245mm 3k stall due to its larger diameter. It will only flash when you want it and will drive very nice around town.
-Brian
-Brian
We do offer a military discount. When you order, tell Chris or Ann and they'll take care of you. Gear is good to know but not a deal breaker. The more gear you have, the better it will drive around town. Good luck with your build, and thanks for your service!
-Brian
-Brian
