Nitrous Outlet Specials!!!
Ok guys this is good untill the end of the month..
Dry Kit Value Pack..
1.Nitrous Outlets dry kit-comes with our halo spray bar,10lb bottle (in Black Or White) fuel pressure safety switch, Nitrous Pressure gauge, NHRA Valve, Blow Down Tube.Regular hardware such as microswitch, bottle brackets, lines, wiring, hardware, ETC.
2.NX automatic Bottle Heater
3.NX purge Kit
4..MSD window switch with the 3,000 and 6,000 pills.
5..8-NGK TR6 Spark plugs
ALL THIS FOR ONLY 825.00 Shipped to anywhere in the US.
NX Wet Kit Value Pack...
1.NX 20920-10 Wet Kit- Comes with 10lb bottle Ice man life time warranty solenoids,Shark nozzle,Bottle brackets,lines,hardware ETC.
2.NX GENX-2 upgrade- Comes with automatic bottle heater, purge, fuel pressure safety switch, nhra fitting, blow down tube,nitrous pressure gauge,wiring and fittings.
3.MSD Window Switch With 3000 and 6000 pills
4.8-NGK TR6 Spark Plugs.
All this for only 975.00 shipped to anywhere in the US.
These kits will help you save some dough..So take advantage while its here.We also have Nitrous filters,switch panels,fuel additives, dual vent purges and remote bottle openers in stock.So ask a sales associate what they can do on the other items you may want to customize your set up.Call in your order today at 1-866-648-7637.
Thanks
Dave
3.NX purge Kit
Thanks
Dave
