p/s line fitting#
p/s line fitting#
I need the part numbers for the two fittings for a 05 5.3 p/s pump so I can get my own lines made to work on a cpp500 box. I have came up with 16mm o ring for return but no other specs on line size or tread etc. Im assuming the pressure side is the same fitting as well?
