Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Throttle Body Harness Conversion Help!!!
Old 02-23-2014, 03:11 PM
DarthVetter's Avatar
Default Throttle Body Harness Conversion Help!!!
I came upon a BBK Power Series 6.0 truck 80mm Throttle Body ( 3 bolt - 8 pin).
I want to use this throttle body on my Blown (A&A) C5. I am trying to find wire harness conversions DBW but I have not found any that work. I have seen the Casper's wire harness but that is for a 6 pin not an 8 pin LS2-LS1 DBW. Is there any way for me to use this throttle body even if I have to splice wires myself instead of buying a plug and play harness converter?
Here is a link that explains the LS1 throttle body pin outs and the 8 pin connector pin outs. they all have the same reference. Basically the 8 pin connector on the side of the 6.0 dbw tb is a combination of the 6 pin on the LS1 tps and the LS1 tac motor.
http://chevythunder.com/drive_by_wire.htm
Is there a plug and play harness or do I need to start soldering and make my own...?
Quick Reply: Throttle Body Harness Conversion Help!!!
