Ev3 to ev6 connectors any good?
K long story short I have an lm7 and need the good clearance. Staying with stock harness and want to use a ls1 or ls6 intake but the injector type is the opposite of the truck ( can't remember which is which at the moment) but has anyone used the adapter plugs and can tell me how well they work? Thanks!!
^ I soldered and glue shrink wrapped new EV6 connectors onto my LS1 harness. I got the connectors for the cheap off ebay. Pretty sure they were off a ravaged v6 ford that they had a ton of.
Just remember that PINK is the common between all of the injectors. This is Batt +. The injectors are ground switched and the black stripe will be different for all of them.
