LSx into a Boxster S
Old 02-27-2014, 12:48 AM
youssa's Avatar
Default LSx into a Boxster S
As the title suggest, I am currently trying to figure out how I can do this. I've been in contact with the folks at renegade hybrid and they gave me advice on a budget build. What I was told was to shop around for a 5.3L Aluminum Vortec engine since that will be able to fit where LS engine could (but for alot less money).
What I'm trying to understand is how that could work? Would a truck engine propel a car quickly/does a vortec easily covers where an LS could be used?
Also, I found a few LS1 engines. One that is missing bearings and ring then has to be assembled (does assembly an engine cost a lot?) the other one I'm just waiting to hear from 'em. Sadly I cannot go make trips to a junk/salvage yard since I am currently in Afghanistan, but I should be back next month.
My hopes are to spend <= 2k on a motor since I'll be on a serious budget.
Thanks for any information, y'all take it easy!
Old 02-27-2014, 07:54 AM
gagliano7's Avatar
Put this in the hybrid conversion section you will get more responses. The 5.3 is just a smaller cube ls1.
Old 03-01-2014, 12:51 PM
cobalt964's Avatar
l33 5.3 makes good power
Old 01-21-2015, 07:24 PM
martsink's Avatar
Did you end up doing the conversion?
Quick Reply: LSx into a Boxster S
