Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Yaw Sensor ?
Old 03-10-2014, 06:19 AM
maroman88's Avatar
Question Yaw Sensor ?
so ive done searching but i havent found anyone with my exact issue. i got the service stability message on the navi screen on start up, the G meter doesnt work and cant get into Competative Driving mode, no dash lights are on, no sudden applications of breaks and no traction control engaging at random.
i pulled 5 codes c0186 c0187 c0196 c0460 c0461.
again no issues with steering, breaking. if i unplug the Yaw sensor, nothing changes, leading me to believe that it may be the culprit.
sound good or have i just been awake for to long?
Old 03-10-2014, 10:27 AM
voodoochikin04's Avatar
have you checked every fuse possible? maybe a blown fuse is causing no power to the sensor, in turn causing your issues.
Old 03-10-2014, 07:25 PM
maroman88's Avatar
fuses all checked out fine.
Old 03-30-2014, 01:55 PM
maroman88's Avatar
any other suggestions?
Old 03-30-2014, 02:51 PM
odthetruth's Avatar
Multimeter if you can get a diagram. Make sure its at least getting power..
Old 03-31-2014, 11:17 AM
maroman88's Avatar
good call, will do
Old 07-10-2015, 08:05 AM
Nastyc4's Avatar
Did you get this sorted out ? I have the exact issue
Quick Reply: Yaw Sensor ?
