Notices
Needed - help with cam install
Old 03-12-2014, 10:11 AM
madmann26's Avatar
Default Needed - help with cam install
So, in short, I am in need of some assistance with a cam install on my truck. The problem I have is I don't have an air compressor for holding the valves up.
I am in the Atlanta area. I can provide all the parts, lunch/beer and possibly some pocket cash (I'll make it worth your while).
I'm doing a quick swap with springs/pushrods/cam. I am not wanting to pull the oil pump off.
If anyone is willing to help me, I can drive to you, we can do the swap, have some laughs and you can make some quick $$$.
I am limited to weekdays due to a busy family schedule on the weekends.
Thanks in advance,
Old 03-12-2014, 01:46 PM
Ego Killer's Avatar
Why dont you rotate the engine so that the cylinder you are working on the piston is TDC to hold the valves up? I have done dozens like this and never had an issue.
Old 03-12-2014, 10:13 PM
70ls1chevelle's Avatar
Same here works great.
Quick Reply: Needed - help with cam install
