got the fix, stripped threads ls1 snout
Old 03-17-2014, 07:40 PM
dcmock's Avatar
Default got the fix, stripped threads ls1 snout
Well I was in a hurry to got my balancer on, used a piece of all thread but didn't thread it all the way in , I knew better but just got ahead of myself, ended up stripping the first few threads out of my crank. I then started searching the Internet and found a Massive Speed 120mm bolt which is about 3/8 longer than stock and is rated the same as arp. I bought a tap and cleaned up the threads and installed the new massive speed 120mm bolt and it worked great, the perfect length and gave me that extra grip that I needed to keep my balancer on.
Old 03-18-2014, 08:07 AM
K STYLEZ's Avatar
+1 I've seen alot of those crank noses get stripped out. Good fix.
Old 03-18-2014, 08:24 AM
grimspyder's Avatar
You got a link for that part?
Old 03-20-2014, 01:39 AM
dcmock's Avatar
I'll post the part # tomorrow with a phone #
Old 03-20-2014, 06:01 AM
JRENIGAR's Avatar
Just search "ls1 crank bolt" on flebay and youll find it.
Old 03-20-2014, 02:22 PM
K STYLEZ's Avatar
There is the new one. I called them. They said it's a new part for them. Said they will have new pics up soon. Not that it would look much different I suppose.
I need one of these for the LQ4 I'm going to put in my old Suburban. Some meat head tore the front of the nose up big time before I got it. MAHW'14220.
http://massivespeedsystem.com/_massi...i-1924063.aspx
Old 03-20-2014, 07:45 PM
dcmock's Avatar
Mahw 14220 this is the correct part # for the longer bolt
Quick Reply: got the fix, stripped threads ls1 snout
