ls3 twin turbo intake temps ?
Old 03-25-2014, 03:10 AM
wooly's Avatar
Default ls3 twin turbo intake temps ?
hey guys just curious to what is a normal daily driver intake temp is ?
mine can get upto 113f or higher.. but seems to be 95f or lower off boost.
I've only got a china front mount so wondering if i should upgrade to a better quality one.
cheerz
Old 03-25-2014, 06:00 AM
rkreigh's Avatar
pretty hard to go wrong with a better flowing bigger, more efficient intercooler
measure IAT before and after the intercooler as well as the pressure drop across the core and that will help you see if the intercooler you have is doing the job.
or just spend the cash on a better quality unit rated for your CFM and HP needs., because you KNOW it will be better. good luck
hope this helps
Old 03-25-2014, 10:06 AM
Blackpanther99's Avatar
cheerz
What intercooler?
Old 03-26-2014, 03:14 AM
wooly's Avatar
hope this helps
thanks mate good info ill try give all that a go and see how good a job its doing..
its just a cheap china 600/300/76 single inlet/outlet…
I'm looking at going TRTTC9 Intercooler
Quick Reply: ls3 twin turbo intake temps ?
