Oil leak when full, no leak at 1/2 quart low.
Anyone had this experience??? Car doesn't leak when 1/2 quart low, but if I top it off it leaks...... Any ideas??????
Car is 2001 Z28.
Car is 2001 Z28.
Have you messed around in your engine bay lately? I once had a weird oil leak after a header install. Turns out my dipstick tube worked itself loose, just enough to let out a small amount every once in a while.
Maybe that is it. Normally no oil leaks. But noticed it was half a quart low about a month ago, so I added a half quart to fill up and next morning a spot appeared. Leaked for about a week then it stopped for a couple weeks... checked level half quart low added 1/2 quart..... another spot of oil on floor. Appears to be from above starter.
Did you seat it in completely. You have to give it a nice little push for it to seal all the way. Felt like it was in there when mine was doing it but it wasnt seated properly. Once i did that the leak went away. Ive replaced every possible gasket in this motor a few years back and so far still no leaks..... knock on wood.
