What o2 sensors do I need
I have picked up a 2006 5.3 that came with a modified harness and 12200411 pcm. The harness has blue/green connectors that fit into the red/blue pcm. The harness has ev1 injector plugs and TPS, IAB, and 5 wire MAF plug. My problem is that I need to know what o2 sensors to use. There is only 1 connector for each side and they are square black female on harness side. I assume it is a newer harness adapted to DBC 2002 ls1 setup. I also assume any o2 wiring was done in the harness for a certain o2 type. Will the 2002 camaro o2 sensors work for me?
