pic of a coated engine bearing for the banana
these bearings promised to play nice with the boost and juice. hey..."boost and juice" rhymes. I may be on to something. lol
What type of coating is that? How thick is it? I assume it must be very consistent in thickness from bearing to bearing in order to maintain crank to bearing oil clearance. Is the coating applied, measured, then crank journals ground to set clearance?
