lq9, milled 317 , ls6 cam, boost, HELP info
well im thinking of swapping in a lq9 into my 02 SS, i spun a bearing so going for a cheap replacement to get her running and going to swap in a ls6 cam and mill the heads while its out anyways to get some power. very small budget so thats exactly what my setup is going to be (no 243, or bigger cam) i will build my ls1 slowly later since it has only 40k miles. my question is how much can i mill the heads if im going to run a ls6 cam which isnt a very big cam. going to run boost aswell so thats why i like the ls6 cam. i saw a build sheet for 600hp using ls6 cam,10psi boost , and 10.2 compression. so pretty much what im going for, any info would help. this would be my first engine swap/build
ive been doing research and what i hear is going with a .04 gasket can do the trick, about 10.2 they say. would that be the way to go? i do have 241s that are from my ls1 but i heard the 317 flow better , thats an option too if i can get more feed back on that
0.04 gasket puts you around 10.16
what gasket would it be because if you are on a budget i would use cheap gm mls gaskets and not worry about the extra 0.25 of a point increase in compression
241 heads would put you around 10.6:1 and imo that is too much for pump gas(Im assuming here) and that small cam.
Running lower compression with a little more boost will make more power than more compression and less boost. 1lb of boost 25-35hp......1 point of compression 5-10?
Keep your heads. Keep stock compression. Boost makes you have big heads. My stock 5.3 stock heads 9.5:1 compression with a truck intake and z06 cam did 590whp at 10lbs on pump thru a th400. Youll be fine leave it alone and save your money. Higher compression youll have to run less boost to keep it from knocking
My bad I thought you wanted higher compression I read it wrong
From your original post it sounds like your on a budget. Honestly if you pick up a lq9 throw the cam in it put some z06 spring in it and leave the heads on it untouched. The money youll spend to mill the heads a half point isnt worth 5hp. Run it stock on pump gas at about 8-10lbs and 13 degrees of timing and it will make power and live a long life. Save your money for your ls1
thanks for your input! , those numbers i would be happy with, dont think i can run 10 psi unless i tightened the hell out of the belt or make a custom tensioner(which i kinda was looking to do due to belt slip) 8 rip upgrade is way too much, i have a p1sc procharger so 8 psi is around where its at.
yeah i am in budget, still in college have other cars as dailys so i have been putting of spending thousands on rebuilding my ls1 but want to get my baby up and running so thats where im at. milling it i can do since they have a machine shop on campus for engineers but i guess not worth the work as you said. i dont see the harm of going to a .04 gasket since engine is out, and lower CR that way cheap and easy. will be getting the springs, do i need timing chain lifters etc if going to ls6 cam or will springs only do?
