LS3 C6 6L80E Issue
Old 04-01-2014, 02:42 PM
Ratdaddy60's Avatar
Default LS3 C6 6L80E Issue
Running into a problem, my car is not shifting (using paddles in sport mode) from first to second when under full throttle. Well now it is starting to do it second to third under full throttle, it simply runs up into the rev limiter, even in the limiter it won't shift. You must lift completely before it will shift. It will down shift perfectly. I can't tell you if it has always done it, as I have never driven it this fast or this hard. It is very frustrating when road racing coming out of a turn, full acceleration, and shift up and it won't shift. Help...Oh, it does it hot or cold...temp doesn't seem to have an effect on it....
Any ideas?
Old 04-01-2014, 08:19 PM
11z71's Avatar
Has it been tuned? Does still do it in drive at WOT?
Quick Reply: LS3 C6 6L80E Issue
