th400 braided lines question
Old 04-03-2014, 01:40 PM
jt_2002_ta's Avatar
Default th400 braided lines question
I'm getting ready to complete my th400 swap and am curious if there are any reasons I should go with braided cooler lines, and if so could you let me know what all is needed. Thanks guys
Old 04-03-2014, 02:40 PM
RENE'S RAGE's Avatar
6-an braided line and straight connectors. Some adapter fitting for the transmission and radiator and cooler.
Some people say to put 45* connectors at the transmission, but
straight connectors work better.
I'll get you a list on the adaptor later today.
Old 04-03-2014, 02:44 PM
jt_2002_ta's Avatar
That would be great, thanks
Old 04-03-2014, 02:52 PM
The adapters are Flare-to-Pipe Adapters.
I want to say -6 AN to 1/4" NPT.
Old 04-03-2014, 04:20 PM
jt_2002_ta's Avatar
Ok, my cooler has the barb fittings, what should I use to hook those up?
Old 04-03-2014, 04:43 PM
The adapters are -06 Flare x 1/2-20 MIF.
I went to the radiator first then to the cooler.
My cooler has the barb fittings also, I just rolled the braid back and put a hose clamp
on it. But they do make a fitting for it to mate up to a -06 AN connector.
I got my parts from Godman Hi-Performance in Memphis, TN.
You can call them and they will take care of you or just ask them what you need.
901-382-7404.
1-800-456-2369
Old 04-03-2014, 05:45 PM
jt_2002_ta's Avatar
901-382-7404.
1-800-456-2369
thanks man, you have been of great help
Old 04-03-2014, 06:46 PM
Z28 6spd's Avatar
901-382-7404.
1-800-456-2369
Earls also makes the -6 x 1/2-20 fitting, part # 991946. I used these on my TH400, just screw them into the factory fitting adapter on the trans where the original steel lines connected. A lot of people think the threads in the case are 1/4 npt, but they're not. You need the OEM adapters in the case plus the -6 x 1/2 fittings to work properly.
Old 04-03-2014, 07:30 PM
You are correct Sir!
Old 04-03-2014, 07:32 PM
jt_2002_ta's Avatar
ok i just looked at my transmission and it appears there is no adapter,the case is just threaded, is there something thats missing?
edit: will this work?http://www.summitracing.com/parts/rus-640520/overview/ says cooler lines to case. not cooler lines to case adapter
Old 04-03-2014, 09:07 PM
Z28 6spd's Avatar
Yes! That will work great without any other adapters. One less leak point.
Old 04-04-2014, 07:45 AM
That's even better than the adapters.
Quick Reply: th400 braided lines question
