what to check
what to check
ok just got done doing shocks all the way around the car and new bushing up front had me tubular lower control arms for about a year .... took the call out to test suspension and it feels and sounds like the back is making a clucking noise what should I check bushing or what??
double check the bolts on the rear shocks, if thats all you changed back there and the sound wasn't there before then it shouldn't take much to find it.
I would suspect you didn't get the top bolt torqued enough, or you didn't get the rubber isolators in position correctly, should go: shock/metal washer/rubber isolator/hole in body/rubber isolator/metal washer/nut. when tightening the top mount you MUST use whatever method the shock has for holding the shaft from spinning while tightening the nut.
