IAT Placement
Old 04-12-2014, 07:00 AM
LsoneGT's Avatar
Default IAT Placement
Hey guys I have a vic jr with arrons elbow, Im switching to speed density so ill be open tb. Im wanting to place the sensor in the elbow and was curious if nitrous and fuel passing it would hurt it. Thanks
Old 04-12-2014, 10:02 PM
LsoneGT's Avatar
Nobody has ever tried this?
Old 04-13-2014, 08:28 PM
FEAR LS's Avatar
If you're putting the sensor in the elbow, how is nitrous hitting it? Are you running a TB plate kit? Shark nozzle setup? Most people run 4150 plates with those intakes...
It will effect it in a negative way. When you go SD you will be using the IAT sensor for fueling control and nitrous will cause that to be inaccurate. You should put it upstream. (Before the entering of nitrous and fuel)
Old 04-14-2014, 10:03 AM
LsoneGT's Avatar
Thanks man I was afraid of that. I was hoping to eliminate any cold air tubing. Ive read a few people just route it to the cowl and strap it down. Im considering doing this. Thoughts?
Old 04-14-2014, 04:42 PM
FEAR LS's Avatar
Where is nitrous entering the system? What I've done and seen work and what I recommend are different things.
I too have a 6061 Elbow (Aarons) and a Vic Jr. I have a 4150 NX Plate kit. I plan to route my IAT sensor either in the elbow via drilling a hole, or in some cold air piping from the air box to the TB.
Old 04-14-2014, 05:33 PM
LsoneGT's Avatar
My plate is directly behind the tb. So setup is vic Jr. Aaron elbow. Plate then tb
Quick Reply: IAT Placement
