Optispark Wire Harness
Hey All,
Its been a while since Ive been on here. I did an optispark replacement back about 6 months along with crank shaft sensor. I still keep getting codes for it and was wondering if it was because I purchased the incorrect wiring harness? I had to modify it by removing one of the plastic guide rails.
The code I keep getting is P0335 - Crankshaft Position Sensor A Circuit Malfunction
Other codes Im getting are
P0400 - Exhaust Gas Recirculation Flow Malfunction
P0161 OBD-II Trouble Code
Any help would be appreciated. The car is running fine with no stumble or stalling issues. I would love to fix these issues.
Thanks
Scott
Thanks
Scott
