Parting out 98 Z/28 Project
Category: Drivetrain
Price: $2500
Part Fits: 93-02 Chevrolet Camaro
Location (State): CA
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Non-LS Part
1998 Z/28 Silver T-top with cloth seats. Car has 208,xxx miles. Rear end rebuilt with 3.73 gears, stock diff, new bearings.
Rear sus: New stock springs, UMI adjustable torque arm, BMR rear sway bar and control arms.
Front sus: All new BMR everything... engine cradle, upper/lower control arms, swaybar. New Bilstien shocks. Newer steering rack. Spindles blasted and painted black.
2002 ZO6 wheels 17x9.5 front and 18x10.5 with new 295s Bridgestones on the rear, could use new fronts.
The car has welded in subframe connectors, PaceSetter long tubes and custom 2.5" true dual exhaust with x-pipe exiting out the back. ECM is tuned by Frost.
The car as a rolling chassie $2750
The new T-56 with carbonfiber syncros and Hurst shifter $2250
Also have a new LS7 clutch and flywheel $375
Motor is honed out with new Wisco flat top piston and rings, arp rod bolts, Comp LSR cam and lifters (have to dig out cam card to find specs), Meilings high volume oil pump, Comp double roller timing chain, Comp Timing cover. New LS6 valley cover and knock sensors. $4500 for short block.
Ben
(831)239-eight two nine zero
