Aerocatch hood pin placement
I have a 99 Camaro and was wondern if any of you guys have installed these hood pins on your car and if so do you have any pics. Trying to see where is a good spot to mount them
Spent a good hour or two looking for a spot to install my aerocatch. Nightfall was coming and light was leaving so we just used the standard type hood pins. The problem with the aerocatch is the steep angle it requires for the pin to fit into the catch. You have a very narrow margin and it wasn't playing well with the curvy camaro.
It could also be that I've strayed too far from factory setup and lost a few attachment points along the way. Best of luck, post pics if you find a spot that works.
