Walboro 255's GSL392
UP for sale is (2) walboro 255's or GSL392's these pumps have less than 2k miles on them. I am selling them as a set and will not separate them. Both pumps come with the -8AN in and outs for easy hook up to your fuel system. Both pumps also come with the rubber insulation sleeve and mounting loop. All you need is two screws and your ready to rock.
These should support around 700rwhp. My goal is 9-1k so I went with Bosch 044's. This is a great deal, don't pass it up.
$120 shipped for the set
These where used with a sump with -8AN fittings so it was a direct plug and play setup. I'm not sure what is needed if running Stock fuel system. Maybe a couple -8AN transition fittings? These are external pumps. I'm not sure if these can be mounted in tank.
