Noise AFTER bushings???
So I figure I've been pressing my luck with countless 40-50 mph burnouts on all stock rear setup. The rear has been perfectly quiet with the exception of the "clunk" (diff bushing). So yesterday I finally replaced the cradle bushings, diff bushing, and trans mount with Revshift and Creative Steel parts. The diff bushing was toast and just fell right out, so needless to say the clunk is fixed. The problem is now I am getting horrible whining from the rear. The noise dramatically changes tone with acceleration / deceleration. I don't think it's the diff though, as it has never made any noise whatsoever. Anyone else experience this after bushings? I'm thinking maybe the drive shaft. When I pulled the drive shaft rear CV a couple of the ball bearings fell out so I pulled them all and cleaned, re-greased them. Oh yeah, I do know all about the 8.8 fix all solution...it's coming eventually.
What hardness did you go for with the differential bushing? The 80A is a softer poly bushing which will transmit a small amount of noise over the stock rubber unit, however, the 95A (race) version will DEFINITELY cause an increase in noise. This is a result of the bushing being harder and transferring gear whine directly into the cabin.
I noticed no increase in cabin noise after installing RS blue rear cradle,trailing arm, and dif bushings with a CS dif block. My drive shaft carrier bearing makes quite a whine, but that's easily identifiable and not easily confused with rear end noises.
Your rear driveshaft CV joint worries me that bearings just fell out. Were the races scored? I don't know anything about CV joints, but it's safe to say bearings should never fall out on their own.
jkel1124 isn't the first one to mention increased noise with the Creative Steel subframe bushings. I'm not sure if he's just sensitive, or if there's really something amiss. The primary sound transmission path is:
- From the differential ring and pinion gear to the front differential bushing
- From the front differential bushing to the subframe
- From the subframe to the subframe bushings
- From the subframe bushings to the body of the car
The only way that CS's design could be causing this kind of problem is if their oversized metal core and flange rings are creating a sound short.
Well I can tell you that I'm not too sensitive. It's not really a dd so I didn't think the 95a's would really bother me. If this is normal then an 8.8 will be coming sooner than later and I can just hope it will somehow eliminate all this obnoxious sound.
Our oversized metal cores do not touch the flange rings that are cast in the polyurethane. There is 3/8" of poly between the two. No short circuit of sound would be possible. The biggest source of sound transmission that I can see in this scenario is the 95A diff bushing. I don't recommend the red diff bushings for a daily driver. Sometimes they get ordered off of the website without questions of suitability being asked.
I didn't see in the first post where the OP designated that he had our cradle bushings. Just that he used a combination of Creative Steel and Revshift parts.
Our oversized metal cores do not touch the flange rings that are cast in the polyurethane. There is 3/8" of poly between the two. No short circuit of sound would be possible. The biggest source of sound transmission that I can see in this scenario is the 95A diff bushing. I don't recommend the red diff bushings for a daily driver. Sometimes they get ordered off of the website with questions of suitability being asked.
Well even though not a dd I've always enjoyed the nice drive ability of my V. My setup sounds and drives almost like stock until you get on it...then whole other beast. Now the rear noise almost covers the whine of the supercharger at times. I'll just have to make due with the radio volume mod for a while.
I hate to leave a thread undone. The bulk of the problem ended up being a bad driveshaft cv so I replaced it. Still had some rear end whine so I installed my spare srx diff with 3.91s and added some 1000hp dss axles. Nice and quiet again. There are some noticeable vibrations from the 95a bushings that are expected but now she's more like a luxury sedan again.
My rear end whine is really bad (4th gen). I could live with it when i just had the UUC Diff bushing installed but now with the Rev shift 95A subframe bushings it is horrible. What was wrong with your drive shaft? I know some bearings fell out but is there something I can check on mine. I am considering pulling my diff this winter to either get the backlash adjusted or find a replacement.
From what I've read (and as others have said here), diff bushing and cradle bushings together can be pretty noisy. I've got SW cradle bushings with a stock diff bushing. You can definately hear more diff whine, but it is liveable.
For what it's worth, I did the SW bushings when the diff was first installed. 60k plus hard miles later, the diff bushing still looks brand new. I think cradle movement really accelerates the demise of the diff bushing.
