How will this cam work with SC
Im in the market for a supercharger, and Im trying to make a list of everything that needs to be replaced or upgraded. The only part Im on the fence about is the cam.
Will it work alright with a supercharger running 12-14 psi?
cam specs (247/251 .623/.623 114+2)
More info in post 3
More info in post 3
Goal is 700-800 rwhp, low 10s high 9s on slicks
It doesnt need to very streetable, but I am going to take it on the highway.
Vigilante 3600 stall
Kooks 1-7/8 headers to kooks true duals. No cats.
More info:
It is already in my 402 and it is surprisingly mild mannered while making a lot of power.
fuel system will be dual walbro pumps in tank with upgraded lines and a return line
compression ratio is about 9.8:1
heads are TFS 225
It will have a f1a running between 12-13 lbs
Meth injection will be used before the head unit and before the throttle body.
80 lb bosch injectors
More info:
heads are TFS 225
