P0141, p0161, p0410 all related
Old 04-21-2014, 04:30 PM
Spink's Avatar
Default P0141, p0161, p0410 all related
Car sat all winter and got it out yesterday and ses light came on with these 3 codes. I hear the air pump turning on and off constantly as well not just at start up like normal.
Rear o2 heaters and air pump are what the codes read. So is my problem the o2s, the pump, or something else. Where should I start?
Old 04-22-2014, 10:35 AM
It's not mine! woo hoo!
demonspeed's Avatar
Probably AIR check valve (the black circular things in the AIR pipes off the manifolds). They get clogged after time and will set multiple codes with the emissions. I had the same issue when I bought my car. I've got a couple extra valves I could send you if you'd want them. Just shoot me a PM
Old 04-22-2014, 04:25 PM
Spink's Avatar
I've had to replace a few in the past and it usually just threw one code for me saying it was the check valve. The one was replaced just last year, less than 1500 miles ago. The other probably has less than 5000 on it. Hard to believe they'd both be bad already. Usually I get at least 35-40k out of them.
Ill give it a look this weekend though. Easy enough to check I guess. And many thanks for the generosity.
Ill post back this weekend
Old 10-19-2014, 11:50 AM
strick 9's Avatar
Just wondering if & how these codes were resolved ? I have the same on my 02' Z28
Old 04-08-2017, 05:46 PM
Spink's Avatar
Updated: solved!
It did end up being a check valve.
Quick Reply: P0141, p0161, p0410 all related
