Unusual power window issue
Old 04-22-2014, 12:46 PM
hoss1059's Avatar
Default Unusual power window issue
My wife's 2001 Z has an unusual issue. You can roll the window down from the passenger switch but not back up. But you can roll it back up from the driver's side switch but you can't roll the passenger side down. Driver's side window works fine.
Would one bad switch in either door cause this?
Old 04-25-2014, 11:22 PM
eseibel67's Avatar
Yes. Your problem is likely in the driver's side switch. If contact cannot be made it will behave exactly like this.
Only other possibility that would cause the exact same thing is wire break or bad connector on tan wire that runs from pin C on the driver's switch to pin E on the passenger's switch. I would probably check for continuity there first because it's easy to do.
Old 04-29-2014, 12:49 PM
hoss1059's Avatar
Thanks much, I'll give it a try then and see what comes up.
T
Old 05-07-2014, 11:08 AM
hoss1059's Avatar
You were correct. Replace the switches on the driver's side and everything returned to normal!
Thanks much,
T
Quick Reply: Unusual power window issue
