Help with injector plug swap truck vs LS1 style
I’m ready to cut my stock truck injector plugs off and wire in my EV-1 LS1 style injector plugs tonight and I know there is a common pink wire for all the plugs and obviously the other wire is the trigger wire but my question is,
Does is matter how I wire in the new plug into the harness? I mean, it shouldn’t matter whether the pink or the trigger wire is wired to a certain terminal on the injector right?
Thanks for the help lol......
Well anyhoo here's the result of my question, I tested the injectors with a 9v battery and they click whether the wires are reversed etc but I went ahead and wired like the factory did, the "pink" wire is common on all the injectors and they were on the "left" side of the injector while looking at the mounted injector and the trigger wire is on the "right" side. I got them done and they work great.
