New LT1 crate leaks....What gaskets are bullitproof?
A little bummed out my motor which is a crate is leakingout if the front of engine and pan. Is this a common problem and what gasket set/sealer are people using. The car is running 10psi of boost and wonder if this causes premature leaking? I am running a oil catch can to relieve pressure. Any idead or recommendations would be great. Seeing a 3 x3 squirt of oil pool under motor at gas station and garage is not something to be proud of not to mention underside getting wet.
