05 cts-v
05 cts-v
Year: 2005
Make: Cadillac
Model: CTS-V
Price: $18000
Mileage: 89000
Private or Dealer Listing: Private Listing
Location (State): CA
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Limo tint
Audio jack for Ipod/phone music through factory stereo
new power steering pump
new falken tires
fresh front brakes/ rear brakes still have a lot of miles left in them
full stainless 3" tig welded B&B exhaust with X-pipe
stainless long tube headers
1,000 horse power G-force engineering anti-wheel hop axles
1,000 horse power G-force engineering drive shaft
UMI solid motor mounts
CS solid tranny mount
have an extra- rear diff that i was going to build with a lower gear ratio but never got around to it yet
have factory exhaust manifolds and cats sitting on the shelf
Engine:
west coast cylinder heads stage 2 cnc ported heads with stainless steel valves and titanium retainers and matching springs to current cam profile
http://www.proheads.com/WCCH_LS6.html
EPS custom grind cam 230/234 112+4 LSA
ARP head bolts
LS-2 timing chain
Melling high volume oil pump
LS-7 lifters
new lifter trays
manley chromoly push rods spec'd and double checked so that lifter pre-load is absolutely perfect
42 Lb/hr injectors balanced and flow tested
car tuned by Cunningham Motorsports out of Temecula, CA 420hp/373ft lbs to the tires
Transmission:
Monster stage 2 clutch with remote bleeder and lightened flywheel
Katech short throw shifter with updated linkage bushings
Suspension:
Hotchkis front and rear sway bars with custom machined linkage with heim joints
BMR trailing arms with spherical bearings
BMR heimed tow links
BMR rear sub frame solid mount conversion
BMR pinion support bracket
Contact Andrew: 714-595-9009
