New injector/pump questions
Old 05-14-2014, 03:56 PM
BigCityFire's Avatar
Default New injector/pump questions
I need new injectors for my build. Apparently my stock ones are at 110 duty cycle at 5600 rpms? This is Japanese to me... I know very little about this stuff. My mods are listed in my signature.
What injectors can I use and do I need a fuel pump as well?
Thanks!
Old 05-14-2014, 07:27 PM
Mike 02T/A's Avatar
You could get the Racetronix fuel pump, some 42# injectors and you'd be set. I'm sure someone is selling some bigger stock injectors in the classifieds on here.
Old 05-15-2014, 05:15 PM
Do I need just the fuel pump and injectors? Or am I going to need wiring harnesses, fuel line, and other accessories?
Old 05-15-2014, 06:03 PM
Mike 02T/A's Avatar
You can get the Racetronix pump/hotwire kit. I believe it will have everything you need for the swap. Change out fuel pump and injectors, then get it retuned. You could probably get everything for under $400, even cheaper if you get a deal on some injectors.
Old 05-15-2014, 11:12 PM
Thank you!
Quick Reply: New injector/pump questions
