Sumped tank 98-02 fbody
I did a search and couldn't find anything. has anyone done this? I have a carb'd 383 on the bottle in a 98 z28 and want to do a weld in sump on my tank. I only find universal ones, I haven't been able to find any 4th gen specific sumps. Please post up where I can get one, what size you did and pictures por favor!
http://www.nastyperformance.com/shop...mped-race-tank
Check that out for an idea. I know you only want info on the sump portion but that will let you see how almost all the external 4th gen guys do there. Most end up doing an aluminum fabbed tank. I don't think there is a model specific sump only if that is what you are looking for, universal is likely what you will have to look for. The metal tank was used so little it wouldn't really make sense to spend time making a part for something like that from a marketing stand point.
This thread has an inside picture of a 98 tank with a sump on it:
https://ls1tech.com/forums/fueling-i...-body-how.html
This thread talks about how to weld it up and some other miscellaneous stuff:
https://ls1tech.com/forums/drag-raci...tank-sump.html
