Cylinder 3 header getting too hot
Old 05-17-2014, 06:58 PM
blacktrans97am's Avatar
Default Cylinder 3 header getting too hot
Guys,
What are your thoughts. If idling for like 15 minutes my cats start getting cherry red. Cylinder 3s header pipe is getting to like 450-500 degrees. 5 is like 350. And 6 is like 300. All others stick around 200ish.
Lt1 383 fresh build. NGk tr55 and also tried tr6. Already checked valve adjustment, wires, changed plugs, and moved injectors around.
I was trying to check vacuum leaks but even propane into an uncapped vacuum port made no difference. Hmm?? Would a vacuum leak only affect a particular cylinder anyway?
Thanks
Doug
Old 05-17-2014, 07:46 PM
Purple Poncho's Avatar
A leaky FPR?? Not sure how that would only effect #3 though.
Originally Posted by blacktrans97am
Guys,
Thanks
Doug
Old 05-17-2014, 07:52 PM
It doesn't appear to be leaking.
Old 05-17-2014, 10:55 PM
DUDCOUPE's Avatar
If that one is runnin way hot then your afr is off on that cylinder
Quick Reply: Cylinder 3 header getting too hot
