Is 68 psi cold oil pressure a little on the high side
I've just put an LT1 into my landcruiser I don't know any of its history other than its a 20 year old engine, I've got an autometer mechanical oil pressure gauge and its showing 68 psi on start up which seems a bit high to me, I've got no doubts about the gauge accuracy coz my old gen 1 engine had very little oil pressure and showed it on the gauge. Oil is new and a bit thicker at 15w-40. I haven't got the radiator hooked up so cant run it for long. I've got an LS engine in my other landcruiser running the same oil and only getting about 60 psi on cold start up (also matching autometer mechanical gauge)
thanks for any opinions
Thanks for the info guys, I got the radiator in and filled with coolant today and run it up to operating temp and have a hot idle of around 22-25 psi so it all seems normal
