Selling a 1998 Trans Am (403 LS2 Stroker)
Year: 1998
Make: Pontiac
Model: Firebird
Price: $11500
Mileage: 150000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
VIDEO:
BLOCK: LS2 Stroked to 403C.I.
CRANK: K1 Technologies Forged 4.00"
CAM: Custom 248/254 .615/.623 on a 112
PISTONS: Diamond flat top with -2cc valve reliefs
COMP. RATIO: 11.1
RODS: Callies Compstar H-Beam w/ ARP Rod Bolts
ROCKER ARMS: Stock
LIFTERS: GM LS7
VALVE SPRINGS: TSP .650" Dual Valve Springs
HEADS: Stock Casting 243 (LS6) -- No porting has been done
INTAKE: LS6 -- No porting has been done
TB: LS1 -- Ported
FUEL INJECTORS: 42lb Ford Green Tops
FUEL PUMP: Racetronix 255 w/ Hot Wire Kite
ENGINE MANAGEMENT: Stock 98' PCM
POWER ADDER: None
EXHAUST: Pacesetter 1 ¾ Long Tubes w/ Texas True Duals
TRANSMISSION: 4L60E -- Level V - Built by RPM Transmissions *Less than 500 miles on last rebuild
CONVERTOR: 3800 Vigilante Nitrous Convertor - Lock Up *Less than 500 miles on last rebuild
Driveshaft: Stock
Front Suspension: Race Craft Tubular K-Member
Rear Suspension: Stock
Drivetrain: MWC Driveshaft loop, Trans. Mount, and Torque Arm
Rear End: GM 10 Bolt, 3.42 Gears
Wheels:
~ Front: Billet Specialties Street Lite's 15X4
~ Rear: Weld Racing Pro Star's 15X8.5
Tires: 275/50/15 MT Drag Radials ( DOT Approved for street )
Fuel: Pump Gas 93 Octane
Weight: 3220 with no stereo
HP: 450 wheel
ET/MPH: 11.30's @ 118- 120 MPH
Call Kevin (317) 694 - 9742
