Install on ID 1000
Install on ID 1000
I have a ls3 with fast intake and fast fuel rails. I'm currently running fast 65 lbs injectors which I am now selling by the way. I just ordered injector dynamics 1000, but now I've read that I need a spacer kit because the id 1000s are a bit taller than the short style fast injectors that I have. My question is has anybody on here installed the dynamics on a setup like mine with the fast intake and fast fuel rails? Where did you buy the spacer kit? Or what did you do. Thanks in advance
I would go on camaro5 and ask that question.
The shops on that site know the exact answer to your question.
You might be able to find the spacers directly from Injector dynamics or from a vendors site.
search google.
search google.
I had that exact setup. I spaced the rail, not the injectors. We went to Ace hardware and bought longer bolts and they have thick spacers. If I recall, I think I went with 1/2" spacers and didn't have any issues. I got rid of the FAST later because I was using a Ysi and didn't need it.
