Rocker arm questions
Old 05-18-2004, 11:09 PM
camman's Avatar
Default Rocker arm questions
I am looking at a set of roller rockers and i am trying to decide on the 1.7s or the 1.8s. I have a set of PP stg 2 LS6 heads with the PP springs that came with them. (im not sure what max lift is on those i have heard .650) and a MTI R1 cam (232 236 .578 .578) and i am curious if i will have problems with 1.8s? if i figure correctly it will put my lift to right at .595 (assuming that the .578 is with stock 1.7s) Will i have problems with my springs with this amout of lift?? Also when would i start running into PTV clearance issues?? I am running flattops with 2cc dish and the GM MLS gaskets and the heads (to my knolege) havent been milled. thanks guys
Old 05-19-2004, 12:10 AM
jrp
SN95 Director
jrp's Avatar
not worth it. for the price of the rockers you can have a new cam ground to the specs w/ the 1.8's :shrug:
your R1 with the 1.8's will be ~ 233-234 / 237-238 .612/.612 with a bit more overlap.
Old 05-19-2004, 09:14 AM
camman's Avatar
from what i have seen the 1.8s arnt much more than the 1.7s i will be buying anyway and thats why i am even concidering them.
Old 05-19-2004, 09:19 AM
HumpinSS's Avatar
Most cam lobes are too aggressive to run 1.8's most sponsors recomend (sp) not using them
Old 05-19-2004, 09:24 AM
PREDATOR-Z's Avatar
Ditto. 1.8's are not recommended for any lift over 0.550.
