What size fitting?
What size fitting?
Running a -6 line to my tank as a return and need a fitting to attach to the quick connect on the tank. What size do I need to run for that? Nate from Nasty performance said its a 3/8 but that seems a little too big because the stock feed is that size..
So the return and feed (at least at the tank) are the same size or is the feed line at the tank actually bigger? I know at the rails the feed line is 3/8 so that's why I am curious.
