injector selection help??
Old 06-22-2014, 11:14 PM
Dustya383's Avatar
Default injector selection help??
So I'm in the midst of putting together my first ls. It's a lm7, completely stock bottom end (new rings and bearings, that's it) tick performance torquemax stage 1 cam, professional products typhoon intake and fuel rails, 85mm throttle body, headers,etc. Which injectors should I lean towards? Any suggestions for size/brand?
Old 06-23-2014, 12:38 PM
Dustya383's Avatar
So from what I've figured, I probably need around a 30 lb injector. We're any of the factory ls injectors rated around that?
Old 06-24-2014, 10:34 PM
ZL1Killa's Avatar
most were 28.8LB @ 58psi rated.
grab some 30# @ 43.5psi rated or even 36# @43.5psi rated injectors, it will give you room to grow and they will run fine.
Quick Reply: injector selection help??
