What size of injectors.
I am building boosted junkyard 5.3 lm7 . Can I run 15-20 lbs of boost safely with e85? Using head studs and ls9 gaskets. I really need to know what size of injectors? What kind of power will I be looking at with this much boost? Also will be using tick performance state 1 v2 blower camshaft.
I think your IDC will be pretty high with 80# @15-20psi of boost. I'd shoot more for 120# injectors. You'll be around 750hp, give or take 50hp with that boost level on a 5.3 depending on your FI setup.
