Help! Cannot figure this issue out!
So I have a built 6.0 with a borgWarner turbo. The car has a hell of a time holding idle. It will idle fine then die. It's not throwing any codes. I've checked the alt. And my pcv goes directly to a vented catch can. My 02 sensors are working and I've smoke tested the car and shows no vacuum leaks. My tuner is very experienced and has no clue either. Any ideas? Also the car will not go above 5200 rpm in 3rd gear at WOT. It just hits a brick wall. Not sure if the 2 issues are related. I've swapped all of my sensors and I doubt my reluctor is bad. Help me!
