Electric Oil Pressure Gauge.. Best install method?
If your engine has doesn't have an oil cooler you can tap the oil cooler block off plate. There are adapters you can buy that replace the oil pressure sending unit and allow you to use any 1/8 pipe thread pressure sender as well.
