2010 camaro 2ss 416 stroker
Year: 2010
Make: Chevrolet
Model: Camaro
Price: $27000
Mileage: 56504
Private or Dealer Listing: Private Listing
Location (State): GA
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Up for sale is a 2010 Camaro SS with 55,000 Miles in very good condition, With a Texas speed Forged 416 STROKER (6.9L) 5000mi on build.
With tons of aftermarket parts built right, With receipts and documentation, and Original Owners Manual. Paint and interior are in good shape,
Tires have good tread, This car is turn key, Ready for the Street and the Strip on the weekend!
Engine
Texas Speed - 418 Stroker
Eagle Rods,
Wiseco Pistons
11:1 Compression ratio
PRC Ported LS3 heads
ASP Harmonic balancer 10% underdrive
Platinum valve springs good to .675 Lift
Custom Comp cam 248/254 .615 .622 lift 111LSA
American Racing Headers
Magnaflow Catback exhaust
Transmission
Professionally Built by Five Star Chevrolet in Warner Robins GA
6L80E with Alto Red friction clutches 1234 35-R AND 456 Clutch packs,
Welded drive shells
Yank 3600 Stall converter
Aftermarket B&M Trans cooler to keep transmission cool
Professional trans tune
GM performance parts Billet aluminum pistol grip shifter handle.
All the weak points of the 6L80E have been fixed and strengthened, Shifts firm and super fast
Power Adder
The vehicle has not been sprayed at this point, But all parts are installed and ready to go. I felt there was no need to dynotune untill it was ready to be sprayed Its been street tuned for now.
When sprayed it would have wasted money on a dyno session . we believe the numbers will hit close 800RWHP, Professional
tuning will be required for nitrous tuning!
Has a FJO tuneable Progressive controlled 250 shot nitrous kit with a custom Nitrous switch panel in console.
Nitrous Outlet Dedicated fuel system for nitrous use. The engine will never run lean, This fuel system provides
the nitrous kit its own fuel supply when activated
Rear End
3.45 Gears(gears from manual camaro) installed In stock housing
