Are the a/c compressors of the ls1 camaro and corvette interchangeable ?
Old 07-12-2014, 05:04 AM
UAE_Z28's Avatar
Default Are the a/c compressors of the ls1 camaro and corvette interchangeable ?
So my a/c compressor broke, and I found one off an ls1 corvette, would it fit and work ?
Thanks.
Old 07-12-2014, 07:56 AM
That's MISTER MODERATOR
Paul Bell's Avatar
They're all V7 65 series but the vehicles call for different part numbers. From what I can see, the pulley is a different diameter. 113mm for the F-body, 127 for the Y-body.
It might work with the right length belt but there might be other differences.
Old 07-12-2014, 10:10 AM
UAE_Z28's Avatar
Thank you for the reply, if its only the pulley, should be fine, anyone else would chime in or confirm ?
Quick Reply: Are the a/c compressors of the ls1 camaro and corvette interchangeable ?
