FAST 36lb (41lb) injectors - 575/600rwhp capable???
Title pretty much says it all. I know it's going to be close and If I had more money right now I would just upgrade, but I don't
The car should make 500rwhp +/- on motor and I would like to use my dry kit to get the rest of the way...maybe just 75hp shot max.
Since all fuel (93oct) is going through the injectors (fed by racetronix 255 w/hotwire) do you think they can feed it?
255 pump maxes at 8 x 51LB injectors...so you should have enough pump
I take it you are running FAST 36# @ 43.5psi rated, AT 58psi, hence the 41.5LB/hr rating?
I'm thinking you are going to be around the 85% - 95% duty cycle range. go for it. shouldn't have problems
