LS1 Grand-Am Cup, 239/251 Duration @ 0.050, Racing Camshaft
Category: Accessories
Price: $250
Location (State): AZ
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
This hydraulic roller camshaft is designed by the GM Racing Division for road racing applications in the Grand-Am series. Serious duration and lift will require that the piston to valve clearance be checked as well as major PCM modifications. For best torque, install the intake centerline at 105; for best power install at 107. GM recommends lightweight valves and valve springs from the 2002-03 LS6 engine for use with this camshaft.
Cam Specs:
Advertised Duration Int - 294 Exh - 306
Dur. @ 0.050" Int - 239 Exh - 251
Lift w/1.7 Int 0.570" Exh 0.570"
LSA 106
Note: When degreeing this camshaft, it is critical that you use the point of maximum lift on the intake lobe. This is not a symmetrical lobe design!
Specifications
Advertised Duration Exh. 306
Advertised Duration Int. 294
Dur. @ 0.050 I/E 239 / 251
Camshaft Lift (in.) I/E 0.570 / 0.570
Camshaft Type Hydraulic Roller
Lobe Seperation Angle 106
RPM Range 4000 to 7000
