Fender paint rubbed off from front tire rub; what is the inexpensive way to fix this?
I have a 2002 Z28 with front 18 inch tires (P285/40ZR18s) that rubbed whenever I backed up at an angle. The rubbing has rubbed off the paint on the rear of the front fenders. After I switch to the proper P275/35ZR18s front tires, I will not want to see that rubbed off area. What is the proper way to fix that rubbed off area? Will I have to get the front fenders repainted or is there a way to just get that specific rubbed off area repainted? What is the cheapest and cleanest solution? Thank you in advance for any info.
if its just the inner fender where the tire rubbed you should be able to buy a rattle can of single stage paint that matches your paint code at autozone or oreilly's and blend it in to the rest of the paint for 10.00 or less... It may not be perfect but wont be noticed unless someone looks very close.
