Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Chevy 5.3 Turbo, engine, accessories, and more
Old 07-23-2014, 11:46 PM
ColtGT4g63's Avatar
Default Chevy 5.3 Turbo, engine, accessories, and more
Category: Engine - Complete Motors
Price: $2200
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): CA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
For sale I've got a Chevy 5.3 engine that came out of my old swapped suburban. This engine is originally out of a 2004 Chevy Avalanche. This engine comes with a Ton of extra's as can be seen in the pics. I ran this engine with a Turbo in the suburban and it ran very well. Here are a list of the things that this Combo comes with.
-Complete valve cover to oil pan long block
-Both intake and exhaust manifolds
-Cable style throttle body, with both sensors.
-All accessories including water pump, belt tensioner, alternator and power steering with mounting bracket. Also has hardline on power steering pump already converted over to a -6 fitting.
-Aftermarket siemens deka 60 lb / hr fuel injectors, with harness plugs converted over to EV1 style plugs
-Fuel rail has fittings to convert the 3/8 quick connect fitting to a large -8 fuel line with straight hose end.
-Oil pan has been drilled, and has had a 3/8 NPT bung welded in place, and a -10 oil return line is provided to provide proper oil drainage from the turbo.
-Engine harness has been modified eliminating all of the smog related components and sensors. All you have to do it provide a constant 12v, and a switched 12v.
-PCM is already converted over to a 2 bar speed density operating system (which is 200$ alone) plus countless hours of tuning to make this engine run good at cruise, and at WOT
-2 bar map sensor is installed in place of the original 1 bar. (55+$)
-fitting in place of original oil pressure sensor, this Autometer fitting adapts the original oil pressor sensor to accept an after market sending unit. has a female 1/8npt fitting.
-Lokar Throttle cable to connect your existing gas pedal to work with this engines throttle body.
-Customer engine mounts and cross member. you don't have to use the cross member, but you can adapt the engine mounts to be used in whatever application they need to be used in.
-Turbo charger is a Masterpower T70 turbo. 70mm compressor wheel with a P-trim exhaust wheel and a .63 A/R housing. This turbo was run at 8 psi on this engine, and worked very well. This turbo also comes with Custom AN oil return line fitting, and custom oil feed fitting. As well as a Vband for the exhaust outlet.
-Several Custom fittings and AN adapters and hoses / lines all over the engine. Fittings and lines alone priced out would be worth well over 300$
-Factory starter, and a flex plate
-2 Denso Oxygen sensors
-D585 Coil packs with aftermarket spark plug wires
-Hub adapter and long flex plate bolts. This is a device that you will need if you want to put an old GM style transmission behind this engine. ( TH350, TH400, or a Power Glide) And to accompany that older tranmission You will want to convert the mechanical speedometer gear into an electircal signal that you can input into the PCM. This tells the PCM when the vehicle is moving to make appropriate changes to the IAC motor while driving.
If you were to locate and purchase all of these items on your own you would not be able to do it for less then my listing price. feel free to Email / text / call me with any questions.
Christiansend83@yahoo.com
858 - 205 - 8992
Dave
Attached Thumbnails Chevy 5.3 Turbo, engine, accessories, and more-securedownload-1-.jpg   Chevy 5.3 Turbo, engine, accessories, and more-securedownload-2-.jpg   Chevy 5.3 Turbo, engine, accessories, and more-securedownload-3-.jpg   Chevy 5.3 Turbo, engine, accessories, and more-securedownload.jpg   Chevy 5.3 Turbo, engine, accessories, and more-securedownload-6-.jpg
Quick Reply: Chevy 5.3 Turbo, engine, accessories, and more
