Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension
Old 08-02-2014, 07:47 PM
JRMClassics's Avatar
Default 2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $9800
Mileage: 10800
Private or Dealer Listing: Private Listing
Location (State): NC
Color: Black
Plans have changed and looking to get rid of my Camaro. Was built and previous owned by Miller Race Cars.
2002 Z28 with 10k original miles. Still smells like new inside and doors close like a brand new car. Car needs a motor and trans and is strip ready. Ran very consistent 9.80s with previous LS7 / TH400. Suspension is dialed in and car launches straight. This car was not hacked up at all, bump stops were removed but wheel well and quarter lips are still factory.
- BMR Tubular K-member with manual pinto rack
- BMR Tubular uppers
- BMR Tubular lowers
- Spohn Extreme body mount torque arm
- Weld-in tubular subframe connectors
- Moser 12 bolt with 4.30 gears and lightweight spool
- Wheelie bars (trunk pan has very clean cutouts to clear the bars that look like they came from the factory that way)
- MRC billet anti rollbar
- Tubular adjustable panhard bar
- Tubular adjustable lowers
- Strange brakes all around
- Strange coil overs up front and strange shocks on the rear
- ABS delete with adjustable prop valve
- B&M ratchet shifter with line lock / transbrake button
- Line lock
- Progressive N2O controller in the dash
- 10-point cage with swingouts
- 5" tach with shiftlight
- AC firewall delete panel
- Relocated battery with trunk switch
- Billet catch can
- Aftermarket lid with ram air
- Weld Alumastars with 28.0/10.5-15 Hoosier slicks and 27.5/4.5-15 M/T ET front runners (also have an extra set of 6" wide Alumastars for the front to run a wider tire)
- VFN Cowl Hood
- Grillcraft Billet grill
- Tenzo Racing seats with G-Force 5-point harnesses
- Factory LS1 / T56 wiring harness and PCM
I'm sure there is more that I forgot to mention. Also have Dynatech long tube headers and complete TSP true dual exhaust that was on the car along with a complete 4" catback with Spintech muffler.
There is a ton of money in this setup and if you're looking to hit the track all the hard work is down and this roller is ready to go. Looking to get $9,800 as it sits.
Any questions feel free to call or text.
336.339.6867
Rick
Attached Thumbnails 2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140524_111542.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140512_174906.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140511_181846.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20130802_174126.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-02-z28.jpg
2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-2002-ls7-camaro-launch.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140802_183421.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140802_183352.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140802_183402.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-camaro2.jpg
Old 08-02-2014, 08:32 PM
More pics.
Attached Thumbnails 2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140524_105433.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140511_181946.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140511_183251.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140511_183309.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140524_110035.jpg
2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140607_183108.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140524_103452.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140802_183229.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140802_183221.jpg   2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension-20140511_183805.jpg
Quick Reply: 2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension
